FBL Gyro MicroBeast Plus Tail Issue
Marcello
Hello, I'm having a problem setting up my Trex 500X with the MicroBeast. In Menu E: Rudder Servo Limit, I'm able to set the limits including the Purple/Red light cues. When I get out of the setup and startup my DX9 and Heli in flight mode, the tail servo barely moves? I've tried resetting the limits but it doesn't change anything. The Servo specs/pulse etc. is confirmed.
Also Menu F: Gyro Servo Rudder Direction, when I swing the heli with my hands right/left to see if the blades are compensating with opposing direction, it works in this menu but not when I’m in flight mode, is this correct? The swashplate works when moving it around but not the tail.
Hello Marcello and welcome to the forum :). I was going to suggest if you have the right frequency match with the tail servo and the beast but you mention the servo specs is confirmed. So I can't help you but In time, other will chime in.
