stokke
And the Gov on your other heli is for a nitro correct? That is totally different to keep the engine from over revving.
No, the JR is electric as well - but will be running GOV.
OK, I hear you both (Gaba and Tony).
I don't have any experience on this GOV matter. But I have an idea about what it does, and I want to try it out. As for my "resource" on GOV on my 450, there are three whole pages in the instructions on how it works and how you set it up. I realize the ESC and motor are made for each other, and this just makes it "safe" for me to experiment with. As far as I have gathered, this ESC (Align one) also reads the motor as other after market ESC's would do, it won't need any sensor or anything. I don't expect using GOV will do anything for me, but seeing how stupid easy it is to set up, I'd like to try it out.
My theory is this;
With a curve (100-95-90-95-100) I will always have a RPM drop on center stick. On multiple occasions I've read that this is the recommended set-up when running ESC with curves. I don't remember why, but it's not recommended to run a straight line e.g. 85-85-85-85-85. It's also not recommended doing 100 across the line because this wears out motor.
With GOVERNOR enabled, I can run 89-89-89-89-89 (instructions states not to exceed 89%), and the middle stick RPM drop will be gone. Or at least, that's the point LOL.
Are these pages in the manual for the esc or somewhere else. Hey I would wanna read that.
Ok.. drop of rpm at mid stick ? thats interesting.. ITs supposed to be the exact opposite cause you come off pitch coming to zero pitch at center. I am running a straight line throttle curve... But I might change it a little. The one reason you are seeing an rpm drop is because your throttle percentage is set at 90 on that point.. Thats why i am running straight line throttle curve at 85percent flat.. any reason you say why its not recommended. I havent done a whole lot of research on it. May be I will learn something new!![]()
Hey! when you make those changes. make a video! before and after... how you did the settings. Was it good, bad or useless ? whatever it is! it'll be good to add here!![]()
I just found this :::::: for BL35P esc that comes with the Align kits. there is a locator beep option. ! Thats awesome!!
If you are running a flat T-curve, when you add collective, you will bog the motor.
Hey Marius, how much collective and cyclic pitch are you running now?
Give the 9º a shot and see what you think.
The Gov is effectivly creating the V curve for you, and this is why you are not seeing any change. There is a reason they will only allow you to have a max of 89 on your throttle curve. that is so it has 11 points to raise the power for the motor to keep it from bogging so much.
