rjhenry
Hay guys, I would like to share something I found on my align 450. I moved the swash links closer to the
center hub of the servo horn to get straighter links, in doing so, it raised the swash slightly
so I had to go back through the head setup to re-center the swash, check zero pitch at mid stick, and
Full travel plus and minus pitch. When I poped off the uppermost pitch link to make an adjustment, I found
It was cracked and practically fell off in my hand. Just imagine if I had not found that and spooled up !!
Just thought I'd share that to show the importance of regular maintenance. It may be a pain, but finding
that bad link most certainly saved my helicopter from disaster.
But now I do have a question. I have to make full terms on my links and one turn goes either
slightly negative or slightly positive for zero pitch at mid stack. If I can't get it perfect
Should I leave it negative or positive, or does a half degree even matter (I don't have a digital
pitch gauge but it's a half degree or less). I would love any and all opinions.
Thanks, Bob
Thanks, Bob
