Hi,tnx for information,definitely a pain still rather haveMy charger has two different rates of discharge. If I discharge on standard 36v power supply it takes longer than if i was on a 12v deep cycle. Either way it still takes forever.
yes definitely a pain,tnx for your infoMy charger has two different rates of discharge. If I discharge on standard 36v power supply it takes longer than if i was on a 12v deep cycle. Either way it still takes forever.
Hey smoggie just used that discharging gizmo (got the exact one you suggested) and that thing works fast ,like really fast!! Only used it on 1450 6s at moment but tnx for that,I was dubious that 3 light bulbs would work that well but it's amazing
First, you not suppose to leave your batteries fully charged for more than 36 hours. The charge in the cells start to diminish the cells. Always put them in storage charge, store them preferably in a area to your home then when you're ready to use them, you can charge them 18 hours before flying. I have done this and I don't hardly have issues with my batteries. I use an i-charger 406. I always charge them @ 1c, normal balance. I rarely use the Fast Charge setup. This is the most recommended way, but some strongly disagree with the method. Again, It works for many.
Second, and what works great for me, I use a LiPo balance charge meter and leave it plugged in. Of course you do this on the balance cable. I set mine meter at 3.7 and it works great on every Heli I own. When the cells hit 3.7v, the alarm goes off, then it's time to land. They always stay around 3.5v's give or take a few tenths. To set the meter, there is a small button in between the ears of the meter. Plug it in and you will see how easy it is to set. If you fly 3D, your flying time will be shorter vs. flying around having fun, you max out your flight time this way.
Any questions, just let us know,
Dennis
The arrow points to the set button between the ears.
Nice one,I see on your list you've got some big stuff,can't wait to see themRick,
Chargers aim for a storage voltage in the 3.8V to 3.85V range. On the other hand exact storage voltage isnt critical, anywhere between 3.7V and 3.9V is ok, so you can usually just put the batteries away after flying without the need to 'storage charge'. If your batteries are going away for a long time (like over winter) then it's best to have them toward the upper end of that voltage range to cover for any slight self discharge that might occur in long term storage.
PS......If the sun is out on Sunday I'll try to get a pic of the whole heli fleet, I've been meaning to do that for a while.
