I finally figured out what the deal was on this gyro, I got a wild hair and decided to switch the voltage output on my SBEC to the 5v instead of 6v and it works now! So this is no longer for sale guys. Just have a question about it, Can I run a Step-down voltage regulator between the RX and the Gyro so that only the Gyro is getting the 5v of power instead of powering the entire RX and Servos so that I don't slow the rest of the servos down?
Well I just decided to experiment a little with using the step-down voltage regulator and it seems to work really well when I put it between the RX and the Gain channel input to the Gyro with having the SBEC set to the normal 6v output and regulating the gain input to gyro down to 5v!
