450 Ikon self level setup problems
codeblue
Hi guys,
Just got the new ikon aluminium. Ran thru the basic setup and got the gov set up and then proceeded to set level and enabled one bank for self level but the slider to select SL doesn't stay on. Not sure what I'm missing. I've searched everywhere for anyone with the same problem but to no avail. Any help would be great.
In the "Flying Style Setup" tab....did you check the box for "Use Auto Level"?
Yes, that's what I've been trying to do. But it just u checks itself when I leave the window and come back. Also another question. In transmitter set up there are a few places where I can't make +\-100 and my endpoints are already maxed out. Is that maybe why it won't let me select? How do I proceed?
sounds like u may have to reset your transmitter an zero it out i had the same probs when i first installed my ikon reset the ikon to factory settings and do the same with your transmitter see if that helps.
also forgot to got in exact order on the ikon set up tabs.
