I finally got the heli in the sky since the upgrades and main shaft replacement put in. I now have a wobble in the heli. I also have to re setup the gyro and forgot to for this new servo so that could be some of it, the rest not sure. I am hoping the exceed motor is no the root cause if so then I will be waiting till I get home to fly again.
Heres a thought; could the main blades cause it to wobble it they are to loose?
I did the whole hold it on its side and give a quick jerk and they fall to about 45 degrees. the motor is flush tight on the motor mount, links appear to be good, nothing appears bent and I rechecked the tightness of everything.
I just took a pause from this post to set the gyro up. I wont know anything till after I charge the batteries again. Blades balance well, just need to check tracking.
