How to post pictures
Slobberdog
When you reply or make a thread at the top you will have some tool bars,
3 items from the end is a picture frame, click on that,
then click from computer,
then choose existing then find your picture,
then click upload file,
and that's it
No problem, John!
There is an icon, in the comment toolbar, that kinda looks like a picture frame. Simply click on that. There will be a window that pops up with two tabs to Insert a Picture from....From Computer and From URL. Simply select which tab, most likely from your computer. Go through and follow the easy steps after that and select your picture that you want posted. There will be a progress bar, briefly, as the picture uploads, then select OK. That should be about it.
Tony does have a request that we keep the posted pictures to a reasonable size, so please be sure to resize the picture so that it's not massive.
Good luck and I hope this helps!
Whoa! Kev...that was fast, lol. You and I must have been typing at the same time, lol. Well done buddy!
When you upload the images, you will just put a carrage return into it and put your text in there.
