General Heli spinning
izatsharizat
hi all,
I need help. My heli spinning ccw when trothle almost 50%. Any idea why it happen?
I'm using Futaba gy 520, TX JR DSX7. is it because some thing wrong in my gyro setting or the TX.
Thanks
This is a very common question/problem.
Its more than likely your gyro is reversed.
Menu 2 in your gyro is for gyro compensation direction. Default is (Normal 2 blue flashes) Reverse is 2 red flashes. See what yours is set to and switch it to the other. To check if its working in the right direction before trying to fly it, hold the tail, move it to one side and watch the tail blades. If the leading edge of the blades points to the opposite direction from the way you are pulling it, its correct.
