450 Gaui X3 motor pinion
Hello, I just received my parts for my X3 today. I'm getting ready to put a motor pinion gear on it. I would like to get a little more flight time then I do now, 3 3/4 mins. I,m running the Xnova XTS 2618 1580 10p motor with 13T, Gens ace 1200mah/22.2V40c. My throttle curve is 75%@ stunt 2 and 80%@ stunt 3. My question is should I change my motor pinion from 13T to 12T or even 11T OR should I change throttle curves or both? I would like to be able to do flips but be able to fly inverted without losing the punch. I'll take suggestions on what motor pinion/throttle curve combination will be helpful. I appreciate the help. I'm trying to get all 3 birds up and ready for the park this weekend, I hope.
You can go down a tooth and get that motor up were it is doing less work .
your Throttle cure should go up in stunt 2 in the 80% range and stunt 3 In the 90% range
you will pick up a little time
Thanks Jesse for the reply. Will do and I'll take it from there and see what happens. Every little bit helps :)
