The stuff that I use is 4.75mm thick (3/16"). You can use anything from 4mm to 6mm and it will work just fine. If you are goign to use something like depron though, you will need a lot of spars in the plane to help strengthen it. On foamboard, the paper does a LOT to make it strong.
