600 Dx9 settings
Rikrik51
Hi,I need some throttle and pitch curve settings for dx9 for use with my trex 600 Dfc with ar7210 spektrum beastx please help also some gyro gain figures please again tnx in advance
Rick.
Below I will post what I use for throttle curves, pitch curves and gyro gain to start off with.
Throttle Curve: 0 75 75 75 75 for normal mode. Don't expect you are flying in idle up yet, but if you are, just a flat 85%
Pitch Curve: 0 25 50 75 100 Keep it linear for the best performance IF you are running idle up, if only in normal mode, then run 46 48 50 75 100 to reduce the negative pitch.
Gyro Gain: Start off with a +45% and see what the tail does. Make sure you are on the Gear channel and set it to whatever switch you want.
Hope this helps.
hi Tony sorry to bother you again but on the 2nd set of pitch curve settings you put 46 68 50 75 100 did you mean to put the 2nd figure as 68?
Regards,
Rick.
We have a scheduled simulator session with Phoenix every Sunday at 1900 central time here in the US. That may be somewhere around midnight for you over there in the UK.
