Dennis H
Well, I thought I had everything set up and running, and I did.
Futaba recommended I switch my 7008 RX to the 12 channel setting. I did so today. I first set the 7008 to the 12 channel mode (2 lights blinking). I cut power to the 7008.
I then powered up my Futaba 14SG, went to the link setting, changed it to 12 Channel, verified it, and cut power.
I then linked the 7008 with the TX. All proved out OK.
I cut power to all. Then I repowered my TX, made sure the 12 was on the LED screen, then I powered up the RX. All went great. The servo's moved like the are suppose to and all.
I have aileron, elevator, rudder, throttle, BUT now I don't have any collective response, none. The servo's move as you check tilt, yaw, and elevator, gyro works normal.
I have tried everything including switching back to 14 channel mode and the collective is not responding to the transmitter commands. I even set up a new model just to check, no help. I have relinked the 7008 several times just to make sure there is no problem.
I have checked all settings in the 14SG.
If there is going to be a major problem, I will find it!
Anybody have an idea where my collective has stopped. There is "0" response, but throttle is a OK. LED shows all functions on the TX are working.
Thanks, Dennis
Thanks, Dennis
