sarconastic
I thought I would share one minor change I made to your RC Help Trainer for the servo mount in the middle of the fuselage. I started with the foam H shaped pieces on the plans, but couldn't get the servos in the way I wanted. So I cut them out and made two flat sticks the same size as the openings in the fuselage. Then cut them the same length as the width of the fuselage foe each one. I dabbed a little hot glue in each hole and slid them in. I dropped the servos ontho the sticks and then marked the holes for the servo mount screws. I used a piece of a paper clip that I cut and put in my cordless drill to predrill the holes for the servos, then screwed them in place. They are solid as heck.
Thanks
Woody
Thanks
Woody
