I would remove the boom and boom blocks and just sand a bit of the mating face of the boom blocks this will allow you to clamp a bit more, or add a layer of scotch tape around the boom that goes into the clamp blocks,
put a servo mount on the boom and use it as a stop block for the boom, adj the tension of the belt then slide the servo clamp up to the boom block and secure it off, that should stop the sliding
