Micro Blade MCPX BL2 help
kenkadish
I want to calibrate my mcpx bl2, and have a question. I am using a Spektrum NX6 radio. Per the manual, I move the sticks to the lower outer limits, and the board blinks red and blue. I hover for 15-20 seconds and land w/o using throttle hold. How do I end the calibration process? Pushing the bind button does nothing, so I suspect I do not have switch "I" set correctly. Can someone tell me the proper setting for the "I" switch please?
Thanks...
According to the manual for the MCPX BL2 ... to finish the drift calibration you press the Bind button on the transmitter after landing as you described. The Bind button ( I ) is not programmable so there is no settings for it.
If it isn't finishing, I'd suggest re-reading the manual for the heli to see if you missed something in the steps for the calibration. The manuals for both the heli and transmitter are on Spectrums website.
