FBL Gyro Assan GA-250 Gyro Manual
There is a later version Tony... The last ones I got had a five red light flash in the servo selection for default setting... Not sure if anything else changed...
If you have the PDF of it, post it up here on the fourm. I will then replace the one on the server.
I have a stupid question for ya'll. I think I know the answer, "no". Here it is: Will the GA 250 gyro (mine is assan) work better with a higher voltage? It is rated up to 9 volts according to the manual. Or is it one of things where the voltage does not effect the performance as long as your voltage meets the power requirements.
