Graham Lawrie
During my current bout of insomnia I flashed my 3gx from 3 to 3.1, easy enough
I then checked everything and spooled up, tip over in forward direction imminent so I spooled down.
Removed head and checked swash, completely level?
Went through 3gx set up all ok?
Set up 3gx on laptop and adjusted pots as per Westy and Gaba, s suggestions put both to 105 like video.
Spooled up, same thing, she wants to tip forward, several identical attempts and nearly one lift off??
Running out of idea's? Could it be 3gx and vibration?
P&T curves linear.
Am I just chicken and should I just lift off rapid? Costly repair if I am wrong. If I had somewhere local to take it to I would be going.
P&T curves linear.
