450 450FBL tail servo
Dougf
Can anyone recommend an alternate tail servo for the Align DS520?I have purchased an unfinished Trex450 with no tail servo fitted and am finding the DS520 hard to find.As a pensioner I can't afford some of the prices quoted for some of the "better" servo's.It has the shaft driven tail rotor fitted so the fitting is for 4 screws.
Dougf
I looked at the DS525M servo which are reasonably priced,it says in the description that they fit the 500 series heli.Are they OK to fit to a 450?I was thinking that they were too big to fit.
Yex, they are the exact same size as the DS520m, just better. And if you are running a Pro frame, you have to have this size servo. It is a 500 size (mini vs the micro size on the swash) but trust me, they are better than the DS425m servos. If you are running a boom mounted tail servo, this servo will still fit no problem.
