My 450 pro dfc has seemed to pick up a wobble. Idle up 1 is fine but when I go to idle up 2 (more head speed ) it wants to wobble up and down from tail to nose. Its not that bad, but not as steady in a hover as in idle up 1.
Yeh, as your headspeed increases, the heli becomes more sensitive.
So reducing the cyclic gain on the axis thats wobbling. So for you, elevator.
As you say its not that bad, just adjust by a few points at a time.
Hey mousie, i was having the same problem and it was driving me nuts, beside the wife, and it turn out to be the DFC shaft had a slight bend to it. Wasn't much but enough to be annoying. Good luck
