Micro 130x Elevator Servo mounting
EyeStation
It appears my front servo board is loose. The exploded diagram does not show screw mounting placement. I am wondering how this servo is secured and how can I replace the screws if they are missing. The top two board holes do not look like they have a backing plastic tab to drive a screw into, and I cannot put a screw driver through the front access hole between the battery tray and 3 in 1 to get to the lower holes.
Any suggestions?
That servo is sandwiched in grooves on both frame halves with no screws, and should not come loose, if it is you have either damaged the frame or the servo.....
Thanks for pointing that out. I had a couple frame screws not fully seated. Seems I've only been keeping an eye on the boom mount screws.
After tightening up the frame screws with the 3 in 1 out of the frame, things have snugged up properly.
I appreciate your response Kev.
