Windows 10 will not load disc it just spins ??
from there site?? View attachment 19819
Rdsok, Yes sir it was spinning up at a high rate of speed for 15 min or so til I stoped it, kept backing out and re running exe it finally wentI'd gotten the wrong impression earlier when you said "the disk just spins"... It obviously loads and starts to install. The "just spins" part indicates nothing at all happens when it actually did but it wasn't able to complete the process ( unless I'm misreading you still )...
What bigone5500 suggested is as good as anything to try... on either copying the disk to a folder on the hard drive before trying to install/upgrade or even trying to upgrade in steps to see what's going on.
As admin, ill try your suggestions, will be cool to have update phoenix..
