DX7 TX
AR410 RX
Skylord 40 amp ESC in a Dynam Waco
So I set up the radio, then hooked the RX to a switched mule battery, bind: no problem. All control surfaces work flawlessly.
Hook up the ESC power up to a flight bat and it gives a high throttle alarm. So I run the trim all the way down hook the bat back up, no alarm. Motor wouldn't run, just growled.. Fixed that as one wire from the ESC was not hooked to the motor. Not sure if that hurt it? I tried it three short bursts, then pulled it apart, plugged in the wire, and the motor spins now, even oriented in the right direction.
Rebind the RX with the throttle trim centered, plug the bat in.. BEEP BEEP BEEP.. Unplug the bat, lower the trim and it works. I get into sub trim, it won't move far enough and I think it limits the upper throttle limit anyway?...
I have another ESC I can try. What a PITA. I finally have the upper wing ready to go on now this...
I think I not only crossed over a black cat's path, but ran over it in my truck! (joking of course)![Warning :warning: :warning:](/images/smilies/warning.gif)
AR410 RX
