Rowdy
I recently switched my esc from a talon 90 to the new spektrum avion 100a. my style has changed over the last couple of years and recently ive always been landing with the overcurrent warning and a talon 90 that was hot enough to cook on lol. So i picked up the spektrum 100a which i swapped out and installed. Keep in mind before i Changed the esc the machine was flying locked in and excellent. now after the esc change, the tail barely holds in normal mode and blows out. Not to mention when i switch into Idle up mode it has a pretty quick wag to it. and as it sits now is unflyable. so to troubleshoot i enabled the gyro on the 3 position switch on my dx8 (i also noticed it said it was "inhibited" before i enabled it) and so i started with 30% gain then took off and landed until i reached 14%. i figured it was a gyro gain issue!? but no matter the value on my radio i turned it too its like im not effecting the model at all. Setup is and was always a weakpoint for myself as there is nobody near me that flys helis, so i have had to learn everything myself. This 550x was my first larger size heli i had, and the person who had helped with the initial setup passed away not too long ago. So i have the passion to never give up and keep learning but i really dont know what to do......any advice would be so appreciated and helpful. thank you all for your time to whomever reads this.
Trex 550x, dx8 g2, ar7210bx, spektrum avion 100a
