falcan
Have found a place in Booragoon here in Perth WA that sells Depron foam high density 3mm and 6mm x 1000mm sheets
DEPRON SHEET
$10.00
Thickness 3/6 MM X 1000MM
Foam Sales' Depron is a closed cell extruded polystyrene that is less brittle than other types of XPS, making it ideal for model making and craft uses. Sold by the sheet in thicknesses of 3 or 6mm, the thinness and firm, yet bendable structure is what makes depron particularly popular for constructing model aeroplanes and architectural models. Offered in white (smaller sheet) or grey (larger sheet) - the larger grey sheets are softer and more flexible, which is useful when tight curves are required.
DEPRON SHEET
$10.00
