Has anyone known of or had a 3GX go bad?
My T-rex 500 is now trashed, and it was not me, I would be a little less pissed if I was doing tick tocs, or funnels a foot off the ground and stuck it in but nope. I was just trying to hover after trying to work out issues and it took off ok, hovered for a bit and then went nuts!
Flipping and rolling can't say it was to the same direction either as I was trying to counter act it to get it back down in one piece but it was just too crazy.
I have had good luck with the 3Gx's until now and couldn't believe all the issues most were saying they have had, well now it's my turn I guess.
Some info on the heli and problem.
I bought this heli used off of HF, it is an older esp I think has DS510 plastic servo's, 1600kv motor and a Hobbywing 80amp esc, belt tail setup.
I had been using a CC BEC and a 3s 1000mah to power all electronics, then align 3300mah 6s for motor. 3GX was 2.1, previous owner updated to v3.1.
The heli had always had a weird twitch since I got it as if the elevator gain was to high, in forward flight it would tip and rock forward. I messed with the gain and it didn't change anything from 12 o clock position to all the way down, even tried aileron gain also. I flew it like this for probably 20 flights until I couldn't get it to stop by changing gains and programming, so I thought it might be the belt tail... Spent $115. for a whole TT setup, changed this out, also bound to my JR11x instead of my DX7s and went through all the DIR, rudder, throttle, flight parameter, setups.
Went out to test fly and it didn't seem to have the rocking twitch anymore, it seemed to hover level but in full throttle flight it would have hard elevator forward, almost to the point of going into the ground, I had to hold back on the sticks to keep it up. Swash was all level and even when plugging it in, it initialized and leveled.
I said screw V3.1 took it back to v2.1 to see if that was it, all the setup again, 2.1 doesn't have dampening in the flight parameter settings so I added expo to my radio after DIR setup. (you can use expo right?) Test flew same thing....!
So I then thought well, maybe the extra 3s 1000mah battery and the 3300mah 6s instead of a 2650 is putting it off on balance didn't feel that way holding it but maybe in the air, i don't know figured I would try it and see. So I removed my BEC and plugged the one back in on the Hobbywing ESC & went to fly, spooled up hovered, started moving forward, same thing with the elevator pushing hard forward. I flip it tail over and hovered inverted for a second, flip back over and then all of a sudden it flips on it's own!
From then it seem liked forever fighting it to try and get it down it kept flipping and rolling on me while I was just trying to hover back to a spot to land, it went over my head behind me, I turned around and about the time I thought I had it, flip SMACK!!!
The previous owner did say he crashed it hard about a year before I bought it but he had rebuilt servo's & everything and flown it since.
Could a crash mess a 3GX up where is it intermittent..?
I'm thinking either 3GX is bad,
HobbyWing built in BEC is CRAP,
or a servo went out on me, but I have replaced all gears and tested them on bench.
I am confused on something tho,
You can't use SUB trim after the DIR setup I know that.
So how is it you can use your trim tabs? or can you not?
And Expo, can you use expo on all versions 3GX?
This is the only one I ever have tried it on and I see where it ended up..
My 550 is v2.0 on my Jr11x no expo, my 450 pro is v3.0 on my Jr11x no expo, after trashing the 500 I flew the 450 for 5 batteries just fine.
Any input or Idea's guys?
Thanks
The scrap pile is almost the same as the save pile, think I have a motor to start with...LOL
SCRAP
KEEP
Thanks
SCRAP
KEEP
