ESC YGE 40A-Throttle endpoints.
Hi guys, I just want a question to make, when using programming card with the yge40A and you set the throttle end points with the transmitter stick, the battery you use that time how many bolts per cell it should be? I used mine not fully charged, neither 3.8V per cell. I used 4 volts per cell when I was setting up the throttle endpoints. Did I make any good?
Hi there smoggie, could you take a look at the 450 size heli category, where I have post a thread of mini titan tail set up? I would appreciate this.
End point calibration is nothing more than telling the ESC where Max and min throttle are. This is based on a signal output
