DAL2855
Banned
I am about to start on the HK550 TT FBL build tomorrow and have been doing a lot of research about my motor and ESC combination going in this build, but cannot find anything about what the timing should be set at for the Align BL-600XL motor and YEP 100a ESC. I have done the formula to figure out the PWM settings and it should be set at 12kHZ if my figures are correct. 1650 x 22.2v x 6 poles = 219,780/20 = 10,989 which would be rounded up to the 12kHZ or should I round it down to 10kHZ? I would think to round up to the higher number.
But I have no clue what the timing degrees should be for the Align BL-600XL motor. Options I have are 0, 6, 12, 18, 24 and 30 degrees of timing. I am thinking it should be either 6 or 12 degrees but dunno which would be the best. I will be running a 16T Pinion with 170T main gears. And do plan on setting up the Gov Store.
So any help here would be greatly appreciated guys!
Thanks!
Oh, and btw, will be running this on a 6S setup not 12S!
Thanks!
