ESC Wiring CC outboard BEC
treff
Could someone explain in simple terms the wiring of outboard BEC into
the ESC and fbl unit. Thanks in advance. Cheers
Update Got it sorted now. Thanks
Glad you got it sorted, treff! Can you show some pictures or video of what you did?
treff
Yes I can but not yet. When I say I got it sorted I found a wiring diagram on the net.
I did not know which ESC to buy. I have gone down the cheap route with a yep 150 amp esc
and a 20 amp Castle bec. So will see if I got it right soon when post arrives. Cheers
treff
Thanks Lee, in the end have gone for something on the cheaper side. 150 amp YEP esc and 40 amp Castle bec. I will add the bug a little latter
when I get everything set up.
