Interference on devices using the same frequency range... when in close proximity ( 2.4Ghz in this case ) can and do often cause interference even when they are on different channels within that frequency range.
Currently the 2.4Ghz frequencies are being commonly used by a wide range of devices... cell phones, cordless phones, WiFi, bluetooth, wireless keyboards/mice, wireless microphones and cameras and numerous other devices.
In addition, while not specifically in any specific radio frequency range... electric transformers, large and small electric motors ( oil rig derrick pumps, electric fans ) and many others also produce interference across broad bands of frequencies that can also interfere with your RC aircraft...
The closer the proximity to other potential sources of interference... the increase in the chances you'll see an "brownout" event caused by interference. How close the issue will show up ... depends on the signal strength of the device. A WiFi signal is going to be relatively strong in comparison to a wireless keyboard or mouse as an example.
