  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General What To Build Next
Discussion in 'Airplanes' started by grumpy1, Oct 8, 2018.
Tags:
< Fms 1400 Sky Trainer Problems | Pls- Help ! >
  1. grumpy1
    grumpy1 I Support Rc-Help! Rc-Help Supporter
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    pipe welder. .pipe fitter. .asme code pipe shop fo
    hull,ga
    All right guys...time to weigh in. Lookin for new project to build..I'm leaning toward 2 I have on a short list..1 balsa usa smoothie xl with 35cc gas power...2 dehavillan dch6 twin otter...electric power...both in the 80ish inch ws...any thoughts or suggestions..
  2. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    My personal choice would be #1. I'm not a big fan of sea planes. I know, the otter is also a land plane... lol. I have just always gravitated towards speed or performance over scale.
  3. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    I agree on #1...speed an performance...you sound like how MOST of the guys fly around here..two throttle settings...take off .....or land..lol..what ya think about an electric conversion? I think flight weight is around 15# so at 150 watts per pound think it would have good flight envelope as well as performance. With those numbers it comes out to be 2250 watts...on paper. To be on safe side have safety margin of 15 percent, with that it comes out to be 127.5 watts per pound. Will it fly? Tomcat 90 motor,2 5c in series,100amp esc. Now there's #2...no one flys or even has a multi motor aircraft around here..fixed tricycle gear, use robart nose gear, many questions tho. Like if motor calls for 40amp esc, instead of 2 esc's, can 1 80 amp esc be used with 2 batterys in parallel.Most of all would have retrain on how to fly scale. .lol
  4. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    Watt per pound I have never used. I have always used power to weight or thrust to weight. As long as you have .5:1 thrust to weight, it should fly without a problem. Will take a little bit to get off the ground. 1:1 is better of course. And one ESC can run two motors, but it is best with two. You can also run two batteries in parallel, but a single larger battery is way more simple. Just make sure to calibrate the ESC's together.
    As for nitro vs electric, that is going to be personal preference. If you like clean, go electric. If you like the sound and smell, go nitro. I battle that question myself lol.
  5. murankar
    Dec 4, 2011
    9,000
    361
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    Just make sure your fuselage can handle the nitro oil mess. I know Nitro will spew oil all over the place.
  6. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    I believe that brushless motors require one ESC per motor
    The first one he mentioned, if built up as it was intended and not switched to electric as was asked about, is a 35cc gasoline model... the second was listed as electric. The gas planes I've seen are much cleaner than a nitro methane motor one....
    While I prefer electric... I have to admire how long a gas motor can last on a tank of fuel.
  7. murankar
    Dec 4, 2011
    9,000
    361
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    Tony mentioned Nitro. I thought I add the oil mess.
  8. rdsok
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    Ah... well, you know truck drivers... lmao
  9. murankar
    Dec 4, 2011
    9,000
    361
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    Yep, not enough black silk.
  10. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Let me a correction...the motor I said I was goin to use on that smoothie is wrong that motor is for my astro hog taildrager edition...waitin on esc for that one now should be here this week the motor for that smoothie is a Tomcat 160...will post pic of astro hog in pics.All the planes I have are electric now. Here's the specs on that 160 motor...think it will fly that smoothie? I like them electrics tho...just had doughts on a going electric on a plane that size...
  11. rdsok
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    That's about the size I'd think would work but I'm uncertain about that brand of motor and if it's any good or not. I've always stayed away from the cheapy motor brands. Tony may have heard more about that brand.
  12. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    Your friggin banned!!! :banned:
    :chuckles:
  13. rdsok
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    You know that wouldn't stop me from trolling you on the phone... or at your house for that matter .... LMAO
  14. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    :dammit:
  15. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    Um, my smiliey doesn't work... going to have to investigate in a couple years from now.....
  16. rdsok
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    :D
    Just checkin
  17. grumpy1
    Oct 19, 2015
    104
    0
    26
    Gender:
    Male
    Occupation:
    hull,ga
    Well fellows looks it's gonna be the.....smoothie on the bench next, I'm seriously thinking about making it electric but I don't know how that will be on a plane that size..any suggestions on power keep this in mind I had rather have it over powered than under powered....rather have it an not need it....than not have it An need it...all them I/c engines seem to require constant cleaning an from some I've seen vibration is always ever present any thoughts:slomo:
  18. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    It really depends on what you want. Yes nitro is messy, but the sound is fantastic. Electric is more responsive and much cleaner. Just depends on what you want.
  19. rdsok
    Sep 11, 2011
    1,671
    60
    48
    Norman, Ok USA
    I wouldn't even consider a nitro engine... maybe a gas one though. The gas one's I've seen are much cleaner than nitro ... but I'd also be leaning towards going electric myself given the chance and the funds
Share This Page
