Motors What do think of this motor
heli-maniac
thank im going to upgrade the motor wile i have the 550 apart
i have the Align bl 600mx now
here are the specs on the 600mx 1220kv motor
Kv (rpm/V) 1220
Max Power (W) 3000W (5sec)
Max Amp (5sec) 150A
Shaft Diameter 6mm
Motor Diameter 45mm
Motor Length 53mm
Motor Weight 280g
Case Outrunner
ESC Timing 5-18 deg
ESC Switching Freq. 16-22KHz
but i think im going to this the price is right
Scorpion HK-4025-630KV (6mm Shaft) - Scorpion Power System
Westy
LEGEND
hey there,
Are you looking to go 12s? or keep it 6s
that motor will give you 10% more grunt .... which is not a lot more of increase.
how about this? ... max power is 5500W = .... well a heap of extra power! if that is what you are wanting! ..... you will have to increase your ESC to a 120Amp minimum..... like a YGE or YEP HV
KDE DIRECT 600XF-1100 HP BRUSHLESS MOTOR
FOR 550/600-CLASS ELECTRIC HELICOPTER SERIES
Kv
1,100 RPM/V
Maximum Current
250+ A (2 sec)
Maximum Power
5,500+ W (2 sec)
Continuous Current
139+ A
Continuous Power
3,050+ W
Maximum Efficiency
91%
Voltage Range
22.2 V (6S) - 29.6 V (8S)
Io (@10V)
2.6 A
Rm (Wind Resistance)
0.007 Ω
Stator Poles
12 (12S8P)
Magnetic Poles
8 (12S8P)
Bearings
Quad, 696ZZ/MR106ZZ
Mount Pattern
M4 x 30 mm, M3 x 25 mm
Stator Class
3532.5, 1Y
Shaft Diameter
6 mm
Shaft Length
46.5 mm
Motor Diameter
46 mm
Motor Length
56.5 mm
Motor Weight
350 g (370 g with Wires/Bullets)
Cooling System
High-Volume Centrifugal Fan
Motor Timing
5° - 15°
ESC PWM Rate
8 - 12 kHz
Here is a 600 flying with one of these installed!
KDE Direct XF Brushless Motor Series - New Release (600XF-1100) - YouTube
Westy
LEGEND
haha ..... ya gotta love the price Vs performance .... turning a light blind eye to the morals of intellectual property though! ;0)
coolgabsi
Super Mod & DEAL KING!
hey there,
Kv
1,100 RPM/V
Maximum Current
250+ A (2 sec)
Maximum Power
5,500+ W (2 sec)
Continuous Current
139+ A
Continuous Power
3,050+ W
Maximum Efficiency
91%
Voltage Range
Io (@10V)
2.6 A
0.007 Ω
Stator Poles
12 (12S8P)
Magnetic Poles
8 (12S8P)
Bearings
Quad, 696ZZ/MR106ZZ
Mount Pattern
Stator Class
3532.5, 1Y
Shaft Diameter
6 mm
Shaft Length
46.5 mm
Motor Diameter
46 mm
Motor Length
56.5 mm
Motor Weight
Cooling System
Motor Timing
5° - 15°
ESC PWM Rate
8 - 12 kHz
Never get too wooed by the max power cause that's just two seconds :)
Recommend using continuous power as a deciding factor .. Which is 3500W so compare that .
Fly safe!! :) have fun!
Westy
LEGEND
Looks like the 600mx does 2000w continuous
and the KDE does 3050 continuous
that is a 33% increase in grunt.
and you can still stick with 6s
The Scorpion you have looked at ... is 12s and sure it is 3500w rated .... but you will definately need to make sure you are running an ESC that is cappable of 44.4v (12s).
The KDE will supply as much grunt as your ESC can supply.
heli-maniac
12 S Is the max it can run.
It is made for 6s to 12s systems
Specifications
Stator Diameter 40 mm (1.56 in)
Stator Thickness 25 mm (0.98 in)
No. of Stator Arms 12
Magnet Poles 8
Motor Wind 12 Turn Delta
Motor Wire 20 - Strand 0.25mm
Motor Kv 630KV RPM / Volt
No-Load Current (IO) 1.1 Amps @ 8.4v
Motor Resistance (RM) 0.024 Ohms
Max Continuous Current 65 Amps
Max Continuous Power 2700 Watts
Weight 326 Grams (11.50 oz)
Outside Diameter 48.9 mm (1.9 in)
Shaft Diameter 5.98 mm (0.235 in)
Body Length 51.5 mm (2.01 in)
Overall Shaft Length 83.7 mm (3.30 in)
Max Lipo Cell 12s
Peak Current 90 Amps (5 seconds)
Peak Continuous Power 3700 Watts (5 seconds)
Motor Timing 5deg
Drive Frequency 8kHz
Just looking for something to Get some better flight time out of it
Was thinking with the lower KV that it would help and its 80.00 bucks not 160 to 260
Even the lower kv 600MX is 140.00 . So i guess ill just leave the 600 mx 1220kv in it
Westy
LEGEND
lower KV usually means more grunt
The 700s and bigger run 560,530,460 .... 8 - 14s
600s.... can run 12s 600mx 560kv (I think) or 6s 1220 - 1000kv
500 can run 12s on 1000 or 1100kv and 6s on 1500 - 1650kv
blah blah
With that motor, if you don't up the voltage to at least 10S, you won't get the head speed needed to fly it properly. My 600 has the Scorpion 740KV motor with 17T pinion running 8S.
I was just about to say this. The KV will not change and you will need the extra voltage to get your head speed back up.
