  2. Hey Guest, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
Cameras What Camera Is This
Discussion in 'FPV (First Person View)' started by bigone5500, Feb 11, 2018.
  1. bigone5500
    bigone5500 I Support Rc-Help! Rc-Help Supporter
    Blog Posts:
    0
    Mar 22, 2017
    1,223
    40
    58
    Louisiana
    I'm trying to find info on this camera. I need to know what the dip switch settings are for the channels. I thought they were TX02 but that camera has a 7 segment display. It looks as if it has MC32 but that turns up nothing.
    @D.O.G. do you remember the model of this camera? It's one I got from you a while back.
  2. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    1,223
    40
    58
    Louisiana
    Well, I have answered my own question. I finally figured out this camera is the one that comes on the QX90. I found the dip switch settings. But for anyone that may be interested, here's the manual.
  3. D.O.G.
    D.O.G. Well-Known Member Goblin 380 Supporter
    Blog Posts:
    0
    Jul 9, 2013
    2,009
    47
    48
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    I thought it was one of the eachine camera.
  4. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    1,223
    40
    58
    Louisiana
    I got this camera to work but there was a problem. Somehow I got the lens out of focus. Can anyone tell me the proper way to put it back in focus? What distance is nominal?
  5. D.O.G.
    Blog Posts:
    0
    Jul 9, 2013
    2,009
    47
    48
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    I think i can help you out. Look real careful at the lens. See the spiral threads going into the camera it self. Your going to need needle nose pliers and turn that ring closet to the camera to the left to loosen up. once you get that loose then turn the camera lens in or out to get it focuses. I stood about 30' away from the object you want to focus. I used my TV as the object. I hope this helps.
  6. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    1,223
    40
    58
    Louisiana
    Sounds good. I suppose some super glue will suffice to lock it in place.
  7. Tony
    Blog Posts:
    10
    Feb 21, 2011
    31,863
    1,205
    113
    Use silicone, not CA just in case you don't get it perfect. with CA, you are stuck with your choice, with silicone, you can still turn the lens and refocus it or replace the lens.
    liquid1 likes this.
  8. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    1,223
    40
    58
    Louisiana
    Good idea.
  9. rdsok
    rdsok Well-Known Member
    Blog Posts:
    0
    Sep 11, 2011
    1,146
    45
    48
    Norman, Ok USA
    Home Page:
    CA would also fog the lens... it sticks to oils and such which is why they use it for fingerprinting these days.
  10. D.O.G.
    Blog Posts:
    0
    Jul 9, 2013
    2,009
    47
    48
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    I used couple daps of hot glue om mine :)
  11. Tony
    Blog Posts:
    10
    Feb 21, 2011
    31,863
    1,205
    113
    Hot glue would work great as well.
Share This Page
