250 What battery?
voo2doo
Hi
I have a TREX 250 and use Turnigy Nanotech cells.I am on 3s 850Mh at the moment.Is there a similar battery as in size and weight with more mh?
Thanks
J
Westy
LEGEND
Not that I am aware of. The only size I have seen or heard of that fits just TP Prolite 910 packs
The only other way you can incresae size is to change the canopy location of hte securing holes back a further 6mm 1/4" and you can fit 1000Mah units
850 is what the heli was designed for. You should be getting about 7 minutes of flight out of them. If you are not, make sure you are balance charging them every time you charge them. I found with a 1000mah it became quite nose heavy.
