  2. Hey Guest, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
Quad WASP 280 Mini FPV Quad Frame from BlueSky RC
Discussion in 'Multi-Rotor' started by Tasajara, Jun 15, 2014.
  1. Tasajara
    Tasajara Active Member
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    I just picked up a NEW WASP 280 mini FPV Quad from BlueSky RC
    This little quad is designed to use the Super 600tvl FPV Camera with 2.1mm Lens
    They also will have the combo WASP 280 Mini FPV Quad Frame with 600tvl FPV Camera
    The WASP will have enough room to place a Mobius Action Camera (Wide Lens Version) - 1080P HD
    on the top or bottom
    I will be using the RCX 1804 2400kv motors I got my motors from
    MyRcMart.com because they had both the RCX 1804 (2400KV *R) Micro Outrunner Brushless Motor (Clockwise)
    and the RCX 1804 (2400KV) Micro Outrunner Brushless Motor (Anti-Clockwise)
    this will keep the props from ever spinning off or ever coming loose.
    I picked up some ESC's from Ready to Fly Quads , F-12A Fire Red series SimonK-(RapidESC)
    My control board will one of two I ordered also from RTF Quads the Flip MWC Flight Controller 1.5 or the Flip32 (V2.1_Rev5.)
    The battery I have on the way is the ZIPPY Compact 1800mAh 3S 25C
    I have a 250mw 5.8gHz VTX I will be placing on board and most likely run this one on 2.4gHz being I want fly it to far out. Use a FrSky 4ch rx Futaba compatible.
    Right now the only thing stopping my build is work, maybe by next week I will time to get started..
    Parts List run down:::::
    WASP 280 Mini FPV Quad Frame or WASP 280 Mini FPV Quad Frame with 600tvl FPV Camera BlueSkyRC.com
    RCX 1804 (2400KV) Micro Outrunner Brushless Motor clockwise and anti-clockwise MyRcMart.com
    Gemfan 5030 2-Blade (Quad Pack) BlueSkyRC.com they have Yellow, White, Orange, Green and always Black
    Super 600tvl FPV Camera with 2.1mm Lens BlueSkyRC.com for fast delivery or SurVeilZone cheaper but may take a few weeks to get
    Flip 1.5 or Flip32 (V2.1_Rev5.) the Flip 32 is a copy of the Acro Naze32 but I can't find them in stock any where so that is why I wanted to they the Flip 32
    As always you can pick up most of the items at a lot of different sights on the web, just get what works best for you.
    BTW The BlueSkyRC Wasp 280 V1 on SALE 25% off, a little spoller is the V2 will have a modded camera mount that will make the Mobuis ride above the Board cam SWEET.....
    You can still Put the Mobius on the bottom as in this pic
    Here are all my parts laid out, the arms are ABS plastic and the cam mount frame is removable... gives you easy access to the control board
    Also all the hardware comes with the frame to mount the board cam and flight controller
    You can get an Idea how small these little motors are, just smaller that a quarter..
    I have the Wide angle lens Mobius, so I will be adding the Mobius Action Cam - LENS SAVER by bophoto
    CAN"T WAIT TO GET STARTED !!!
    Here is a little video to get an Idea how well it handles
  2. Stambo
    Stambo Well-Known Member
    Blog Posts:
    0
    Mar 23, 2013
    1,577
    67
    48
    Whangarei, New Zealand
    That looks pretty cool, I wonder how durable that plywood frame is.
    be interesting to get your impressions.
    I have a set of those motors, some simonk flashed 12a ESCs some 3 blade 5" props and a KK2 ready for a frame I was gonna make up.
    Maybe I'll wait and see how yours goes. :)
  3. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    I have had 5 of the laser cut frames from BlueSkyRC.com they always work very well...
    2 Spider, 1 IFrame, 1 xRotor and a Tri copter.
  4. wolfman76
    wolfman76 Well-Known Member
    Blog Posts:
    0
    Sep 5, 2011
    2,635
    59
    48
    Occupation:
    basic laboror for the moment till i can find sumth
    hammond,indiana
    i hax the spider quad frame from them myself been a good quad it is the avatar i use
    i might just have to get this lil quad very nice and compact looking
  5. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Had a little time today and I got building on my WASP 280...
    Got all the legs fitted to the top and bottom plate, may need to sand just a tiny bit so they will slide in the slots pretty easy
    The legs want be glued in. This way you can replace them if you ever have a crash
    I did glue the bottom of side piece
    I put a little tape on the arms before paint so the ABS arms would stick better when glued
    Time to put the canopy together
    I test fit the sections on both plates
    I only installed the front pieces because it will go together better, plus the last two sections can be installed from the bottom
    I did a quick test fit to my main frame before glue was applied I used the arms to space the two plates as if they were installed
    Fitting up nice
    Time for a little paint.
    I did Orange because this little quad is small and I want something bright if it lands in high grass
    You can see where I taped the arms on the glue tabs
    The arms will only be glued at the motor mount tabs
    Looking good time for my eletriconics
    BTW I got my control board in the mail today WoooHoooo
    It is The Flip32 (V2.1_Rev5.)
  6. Qrome
    Qrome New Member
    Blog Posts:
    0
    Sep 15, 2012
    4
    0
    0
    Arizona, USA
    Stambo, I can't express enough how tough this little quad is. I lost video link the other day and crashed into blacktop and into a cement curb. There was only minor scratches. Picked it up and flew it right away. Wood is excellent at absorbing vibration as well. This is currently my favorite quad right now.
    Oh man, that orange is looking awesome!
  7. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    The orange is so much brighter than the pic shows...
  8. onefastxp
    onefastxp New Member
    Blog Posts:
    0
    Mar 13, 2013
    3
    0
    0
    alabama
    That looks cool I can fpv fly that in the house.it looks tough I can bounce off stuff and keep going
  9. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Yeah the laser cut ply is a lot tougher that you think....
    I got a little more done today....
    Wired up my esc's and motors
  10. wolfman76
    Blog Posts:
    0
    Sep 5, 2011
    2,635
    59
    48
    Occupation:
    hammond,indiana
    Looking forward to getting one of these when I get a lil extra cash.. bout how much for the finished quad minus the control board seeing I have plenty of those plus the mobius. .. can't wait to see the finished quad flying.. great job
  11. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Wasp 280 combo $ 89.99 with camera
    4 - motors $35.96
    4- ESC $32
    Props 1 set of 4 $4.99
    Drum roll please.....
    $162.94 less shipping
    I am sure I will get way more than a few hundred dollars worth of fun out of this quad than what it cost... :yahoo:
  12. wolfman76
    Blog Posts:
    0
    Sep 5, 2011
    2,635
    59
    48
    Occupation:
    hammond,indiana
    I think I know what I am saving for
  13. Qrome
    Qrome New Member
    Blog Posts:
    0
    Sep 15, 2012
    4
    0
    0
    Arizona, USA
    Great looking build!
  14. FLYINGDEUTSCHMAN
    FLYINGDEUTSCHMAN New Member
    Blog Posts:
    0
    Jun 27, 2014
    11
    0
    0
    Seaside,Oregon
    Home Page:
    To save weight you don't need the FPV camera. I use my Mobius for recording and the FPV at the same time. That little guy looks cool. Good job.:smile:
  15. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Yeah I know what you are saying I have the cord to do a live feed out. I just like using the Board came because it does low light better.
    That way I can fly later into the evening.
    BTW
    I got time to finish up my WASP 280 this weekend Hope to go do some FPV today.
    I did add a Pololu 12V Step-Up Voltage Regulator inline between my FatShark 250mw 5.8gHz Vtx 5v output and my board cam.
    Steps up the 5v to 12v makes for a simple hook up.
  16. wolfman76
    Blog Posts:
    0
    Sep 5, 2011
    2,635
    59
    48
    Occupation:
    hammond,indiana
    Man she looks ready to rock Craig. .. nice!!!!
  17. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Thanks about to go out and give it a try.... :yahoo:
    Here are a few more pics
    39-Wasp 280.JPG 38-Wasp 280.JPG 37-Wasp 280.JPG 40-Wasp 280.JPG 41-Wasp 280.jpg
  18. Qrome
    Qrome New Member
    Blog Posts:
    0
    Sep 15, 2012
    4
    0
    0
    Arizona, USA
    Very nice. I can't wait to see the flight report. I am getting one of the Flip32 boards any day now. I will put mine on a WASP 280 as well.
  19. EyeStation
    EyeStation I Support Rc-Help! Rc-Help Supporter
    Blog Posts:
    0
    Jun 22, 2013
    1,154
    55
    58
    It's Dave from Lockport, IL
    That's an awesome build. Can't wait for the video.
  20. Tasajara
    Blog Posts:
    0
    Nov 11, 2011
    911
    44
    28
    Gender:
    Male
    Thanks....
    Here are the settings I ended up with on my Flip 32 controller using also works fine with the Flip 32
Share This Page
