Actually, I need to apologize. I just now noticed that the Tx that you are planning on using is not a computerized Tx. That being the case, you will not be able to do what I had planned on explaining to you. Because your Tx is not a computerized Tx, the only way that you'll be able to setup a plane, with 2 Aileron servos is to use a "Y" servo extension. The two servos will plug into the "Y" servo extension and then the "Y" servo extension will plug into the Rx at Channel 1.
If you had a computerized Tx, we could discuss "mixing" setups and you would be able to trim out each servo individually.
If you plan to continue using the Turnigy 6X FHSS, the "Y" servo extension is the only way to go.
An inexpensive alternative would be this:
OrangeRx T-SIX 2.4GHz DSM2 6CH Programmable Transmitter w/10 Model Memory (Mode 2)
or this:
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)
Both of these Tx's are computerized and programmable. We could get you setup with mixing setups so that you could use separate channels for the same function.
http://www.hobbyking.com/hobbyking/store/__28494__OrangeRx_T_SIX_2_4GHz_DSM2_6CH_Programmable_Transmitter_w_10_Model_Memory_Mode_2_.html
or this:
http://www.hobbyking.com/hobbyking/store/__8992__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Receiver_Mode_2_v2_Firmware_.html
