Scale Unwanted / unchanged pitch curves
Rob Nuss
On my 230S and DXE6 TX I seem to get 1 to 2 degree pitch changes between flights. I'm flying microheli scale fuselage so my throttle curves and pitch curves are linear. Pitch from 0 to 10. Helicopters flies great but when I use the digital pitch gauge, things have changed slightly. Is this just a sloppy, inaccurate pitch gauge or can the pitch curves vary from flight to flight. On a side note, if anyone is interested in scale fuselages, Microheli has 4 beauties for the230S.
Thanks in advance.....Rob
First welcome to the forum Rob :). Once you set your pitch, what you like, in the beginning of the set up...just walk away. If you check your pitch after each flight, you will always get a slightly different reading each time you check it. So I wouldn't worry about it. It's not your pitch guage.
