  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Quad Turnigy 9x Help!
Discussion in 'Multi-Rotor' started by Declan, Jan 25, 2018.
< 2 Or 3 Blade Props? | These Were Cool To See. >
  1. Declan
    Declan New Member
    Blog Posts:
    0
    Jan 25, 2018
    3
    0
    1
    Gender:
    Male
    newcastle
    Hi, struggling to get aileron to go centre it only works 50%+ wont go down to 0% it seems to be tied into the throttle channel?
    Also failsafe, how is It set so you turn the handset off & dji naza m lite goes into go home mode?
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,506
    1,391
    113
    It sounds like you have some mixing in the Tx. Not sure what you are working on model wise, but usually there should be no mixing. Have you tried creating a new model and starting over?
  3. Declan
    Declan New Member
    Blog Posts:
    0
    Jan 25, 2018
    3
    0
    1
    Gender:
    Male
    newcastle
    yes it doesn't make a difference
  4. Declan
    Declan New Member
    Blog Posts:
    0
    Jan 25, 2018
    3
    0
    1
    Gender:
    Male
    newcastle
    This is my problem, stick back all the way only reads 366 when it should read a full value like 966+ like it shows when full forward.. end points are all the same? what is wrong please help
  5. Smoggie
    Smoggie Well-Known Member
    Blog Posts:
    0
    Dec 14, 2015
    2,319
    122
    73
    Aberdeen, UK
    Have you by any chance set the transmitter in helicopter mode with CCPM mixing?
    That's all I can guess, Open Tx firmware like used in the 9X can be baffling and very complex so you probably need an Open Tx guru to advise
  6. Stambo
    Stambo Well-Known Member
    Blog Posts:
    0
    Mar 23, 2013
    1,635
    74
    48
    Whangarei, New Zealand
    Stock 9x is not OpenTX Tony.
    Declan, are you using stock 9x firmware or has it been flashed to OpenTX?
    I'll have to grab my sons 9x and do myself a quick refresher course.
    I never had any problems getting it to work on a multirotor when it was my only TX.
  7. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,506
    1,391
    113
    Um, I never said it was. All I said was it sounded like there was some mixing in it and to try a new model...
  8. Stambo
    Blog Posts:
    0
    Mar 23, 2013
    1,635
    74
    48
    Sorry Tony was half asleep replying to this, was aimed at Smoggie :D
    Have you got this sorted yet Declan?
  9. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,506
    1,391
    113
    lol, I do my worst writing when I'm half asleep hahaha.
Share This Page
