Yes, that was choice and it is with the outer holes.
But, my problem remains, can't get to 6 degrees, I get as far as around 8 degrees.
I am going to follow Smoggie's suggestion to shorten the servo arms.
The problem is that I have the original Trex ESP wheels, not arms. Those wheels have only holes around the circle, to enable choices to get as close to 90 degrees as possible.
To shorten the distance to the servo shift, i have to remove the wheels, transfer the ball links to actual servo arms, and position those closer...
Or maybe, you have another idea. In my mind, my pushrods from the servo links to the swahplate, are too long, which makes the starting point, higher than needed and that's why I get at best to 8, not to 6 degrees.
Your thoughts
Cheers
