700 Trex 700 nitro 9xr setup
1evlfx
Hi has anyone setup the turnigy 9xr to fly trex 700 nitro limited edition??
I'm using all standed align servos and it has gp750 align gyro
Jr propo rd 721 rx
The first thing that I will say is, if you don't have a spektrum module, that Rx probably won't work. I have no idea what the band is on it (dsm2, dsmx, dmss) but for your best bet, use the Rx that came with the 9xr unless you have a module for the tx.
I just did a quick how to on setting up the radio. One thing I did not cover was fuel based. I do not own any fuel helis so I really don't know how to setup the throttle channel with the servo. I am sure there is info on that out there. Your 9xr will need a module since they normally don't ship with one. So if you want to use JR rx's then you will need a JR based module.
How To: er9x companion9x - th9x, Taranis, 9xr
Let me know what else you need on this.
1evlfx
Hi tony I have got the correct orange module that binds to the jr rx
I have bind the 9xr to the jr xr and have all the servos working from the 9xr
But I'm needing to link the thr to the 3 servos to the swash so
It will lift the Swash and change the pitch
