Hey Tony,thanks for your help. Ok, here's the info: the helicopter is the align 600l dominator. Motor is the bl750mx(red head) - align bl815h cyclic and bl855h tail rotor servos. Castle edge hv80 brushless esc, castle25 amp pro external bec. FOR power, I'm using two zippy 6 cell 5800mah packs that I've setup series parallel,and the gpro. I've also installed two spectrum 9646 satilite recievers(the gpro instructions stated that a primary reciever was not necessary if I was using a spectrum transmitter,and I am - the DX9. To answer your question,yes I have a two cell 2400 mah that I used to bind the receivers- using the bec and spectrum 12 chan. Reciever. I've never flown an rc model with out a reciever before so I am somewhat anxious and confused about the installation. There are two lines comming off of the esc and two lines also coming from the bec- all with servo connectors. There is absolutely no visual diagram to illustrate how to connect the servos,esc,and bec to the gpro. There is a vague statement that just says basically to do it. The heli is completed,shy of this gpro installation. I'M really at a loss here,and cincerely appreciate the help. Oh, yes I figure the power packs are a bit large,but I plan to fly a scale hughes500 with them.
