I have seen a few posts where it is recommended that you start with a 45, 47.5, 50, 75, 100 pitch curve. In my setup, I then get -0.7 degrees pitch at low stick thro to 0 degrees at mid and 10 degrees at high. Surely I would need around -2 degrees at low to help bring her down if needed ?
The throttle curve is left as a linear curve from 0 to 100 - is this correct ?
