Good deal, that is the one that I know lmao. Okay, now I need to know what Tx you have as well as what Rx setup you are running. If you are running spektrum, are you ONLY running satellites or are you also running a receiver like the AR6210? If you are using futaba, are you using just the Rx, or the S-Bus cable?
Either way, you are going to need to go into your program and set your swash to 120º 3 servo. Doing this will allow that pitch servo (which goes into the Aux1 port) to start working. You will have to forgive me, I'm trying to get things moved into my new house, so I'm going to be on and off of here for a while. If anyone wants to jump in and help out, feel free. Just rather busy since they got my electric installed and turned on.
