Check all of the wire connections and make sure all of the wires are in good condition, and making good connections. Since you have already changed your receiver, you might also have the transmitter looked at. There could be a problem with the RF signal in the transmitter itself. If you are using Spektrum, and you are running satellites, check the wires going to the satellites. Those have a tendency for breaking inside the sheilding, and can cause the issue you`re having.
