leedude1
I haven't finished the rebuild on my 150 parking lot incident yet. I have however swapped out the tail motor on the other 150 that was causing me some grief. I put in one good flight after the tail motor change where things looked like they should..however with the second battery I'm back to the same issue of the tail rotating clock wise and not being able to hold.
i wondering if this may not be an MRS (board) issue at this stage, as its a brand new motor,new tail rotor as well ...
Gyro setting at 55% to start on the DX6, tail gain on the unit set at 50 to start, and I even started pushing the gyro to up to 75% (some serious wag there let me tell you) but this is just not holding anywhere and just is not flyable.
I'm curious if its not the tail gain pot itself that may be the issue as I started to play with the settings the other day and I wondering if this may be the cause...I've moved the pot to minimum and then turned back from there without any obvious change in the situation so im at a loss at this stage.
Any ideas or has this happened to anyone else?
