BenScoobert
I have just watched your youtube videos on dx6i & ccpm setup.
I have a question that I have asked others and not got a definitive answer.
I have a dx6i and GP750 gyro, I set limits on the gyro and it stops it trying to push beyond the end of the slider and binding. Great, however, in rate mode I have full throw at about half stick, although it is not binding but I have lots of "nothing stick" beyond halfway.
The 2 responses I've had to this are:
1. You don't need rate mode, ignore it.
2. You didn't set it up right, do not use travel adjust to correct it as that will reduce your piro rate when in HH mode.
I had noticed that depending what you set the % at in rate mode depends how far it travels too, at 49% I get less travel, at 1% I get full throw at about 5% stick. Do I just work it out the by using 48-49%?
Thanks
Ben
Thanks
Ben
