Spektrum Timing For Align Mx450 (3400kv)
Jacob Kjer
Hi all you clever people.
Does anyone have an idea of what the timing is for the Align MX450 (3400kv) motor.
You used this equation for determining the PVM
PWM = KV x Voltage x Poles / 20
Can't wait to hear your ideas
Thanks in advance
Timing at ESC default and PWM at highest value supported by the ESC works well pretty much every time.
The PWM calc you quote is for calculating the minimum frequency, higher is generally better. The only reason to lower PWM is if the ESC was getting too hot.
Jacob Kjer
OK, I'll give it a try and get back with the result.
Thanks for your answer
Jacob Kjer
I have now changed the ESC settings accordingly, so the timing is no 12 degress, instead of 0 degrees. PVM sat to 16..
It seems to be better.
