buel williams
os 55hz fan nut on 600 nitro keeps working loose,any ideas
yes and still worked looseDo you have blue thread locker on it?
has anyone ever tried lock washer between flat washer and nut or telfon nut on topyes and still worked loose
problem number two,clamp seems to be sold out or back order onlineNylon nut will not work due to the heat. You can try a lock washer, just make sure it doesn't push the nut too far out. Definitely check clearance.
