  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Spektrum Throttle Curve Setting
Discussion in 'Transmitters & Receivers' started by Hirobo.61, Aug 25, 2018.
< Flight Sim And My Tx | Tm1000 Programming?? >
  1. Hirobo.61
    Hirobo.61 Member
    Blog Posts:
    0
    Aug 4, 2018
    45
    0
    6
    Gender:
    Male
    Occupation:
    Retired
    Kansas City Mo
    I am a beginner at helo-flying ( I have an old 450 LMH 110 electric) and I need some advice as to where I should set the Throttle Curve on my DX6i? Can I also program the Throttle Hold setting as well? Please explain how this is done; I have the helicopter programming pdf but it's pretty vague in these areas. Thank you for your help.
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,522
    1,410
    113
    For throttle curves I always run the same curve on every helicopter, but for Normal mode, you need a good ESC with a good soft start because of the sharp ramp. And you will need to adjust these settings to suit the helicopter and your flying style.
    Normal: 0 65 65 65 65
    IU1: 85 85 85 85 85
    And definitely setup throttle hold and practice using it. That switch can save a helicopter. All you need to do is enable it and make sure it is set to a flat 0 all the way across.
  3. Hirobo.61
    Hirobo.61 Member
    Blog Posts:
    0
    Aug 4, 2018
    45
    0
    6
    Gender:
    Male
    Occupation:
    Retired
    Kansas City Mo
    Tony: on my Spectrum DX6i the options for Normal are L, 2,3,4,H. And for Throttle Hold, it sets up from 0 to 100 percent. How do these options on my radio relate to the ones you recommended?
    Also what is IU1?
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,522
    1,410
    113
    The L 2 3 4 H are the different points on the curve. L is going to be the throttle stick all the way down, H is going to be the throttle stick all the way up, and 3 is mid stick. The other two are in between those. And in my comment, the 0 65 65 65 65 corresponds to L 2 3 4 H respectively.
    IU1 is Idle Up 1, which is the only Idle Up that the DX6i has unlike more expensive radios that have IU2 as well, some also have IU3.
    Again though, make sure you have a good ESC with a slow start before using that curve. If you have a cheaper ESC that doesn't have a good soft start, then try 0 25 65 65 65. This will make it easier to slow spool it up manually. Hope this helps. l
Share This Page
