  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Flight Controllers Tero Q215
Discussion in 'Multi-Rotor' started by sabine, Oct 7, 2018.
< Help Lots Of It | Eachine E010 Thread >
  1. sabine
    sabine New Member
    Blog Posts:
    0
    Oct 7, 2018
    3
    Maine
    I am new to quads this is my first one It is a kit and I will use a Specktrum RX with it any help will be good. I got beta flight and bl heli suit . I am looking for the proper board location for the RX hook up is it as simple as plug and play?
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    34,851
    the pin location for the 3.3v line, signal and ground will be different on every board. We will need to know what board you are using to help you out there. Whatever you do though, do not solder or plug that satellite into a 5v rail, you will let out all of the magic smoke.
  3. sabine
    sabine New Member
    Blog Posts:
    0
    Oct 7, 2018
    3
    Maine
    the board is a Rcharlance F4 pro+ v2
    the processor is f4 (stm32f405)
    this is all I know as i do not have the board yet it is on order
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    34,851
    Here is the pad locations that you need. Hope you have a soldering iron with a small tip. Be careful to not jump pads together.
  5. sabine
    sabine New Member
    Blog Posts:
    0
    Oct 7, 2018
    3
    Maine
    Thank you this will get me going
  6. Dronezipper
    Dronezipper New Member
    Blog Posts:
    0
    Jan 10, 2019
    3
    UK
    Hi Sabine, did you have any luck? I have a TERO Q215 with the same board and had similar problems. I have a FLYSKY FS-I6 transmitter and FS-iA6B receiver and using the supplied plug and port, could not get the drone to work. I soldered the signal wire to RX1, which is on the other side of the USB port and now it's OK.
  7. Echo4alpha
    Echo4alpha New Member
    Blog Posts:
    0
    Jan 26, 2019
    3
    Missouri
    I wonder if maybe you could help me out. I bought this kit about 2 months ago and haven’t got it flying yet. It’s the first quad I’ve built so I don’t know a ton and I haven’t been able to get an FSA8S or FSiA6B receiver to work. I’ve tried soldering it straight to the board. Jacked up the first flight controller and ordered another which had no settings on it so I’m hoping I just haven’t set it up correctly in beta flight.
  8. Dronezipper
    Blog Posts:
    0
    Jan 10, 2019
    3
    UK
    Hi, when you say you jacked up the FC, do you mean that you binned it? Which FC did you get?
    For the connection, the positive and negative went to the little 3 pin connector/plug, and the white lead I soldered to the RX1 tab
  9. Echo4alpha
    Blog Posts:
    0
    Jan 26, 2019
    3
    Missouri
    Hey thanks man but I actually got it figured out after a sleepless night. Instead of using ppm I tried ibus. Originally when I got the kit I burned up the first flight controller. I ordered a new fc same as the one it came with and got it hooked but every time I went imto the receiver tab in betaflight it didn’t show any response to my transmitter. Last night I tried the ibus settings and it worked. Like I said I’m new to this so I didn’t realize using ibus was even an option. Thanks again.
  10. Dronezipper
    Blog Posts:
    0
    Jan 10, 2019
    3
    UK
    Glad to hear that you got things sorted
Share This Page
